Exhaust popping on deceleration (1.7 D-Jet), After changing MSP for a rebuilt one |
Jazzy |
Jul 12 2018, 03:57 AM
Newbie Group: Members Posts: 32 Joined: 16-September 17 From: The Netherlands Member No.: 21,432 Region Association: Europe |
I have a '73 1.7 with the stock D-Jetronic installed. The engine was lacking power, overall and especially around 3k rpm, so my mechanic and I checked everything from sparks to fuel. Started with the ignition and replaced the system with a new 1-2-3 ignition, coil, spark plugs and cables. Huge improvement, especially more torque at low rpm.
Next the D-Jetronic parts were checked and discovered that I had the wrong MPS and two 2.0 injectors. The injectors were changed with proper ones and all four tested. Fuel pressure was slightly off but everything else looked good. When I got the car back from the shop I ordered a rebuilt MPS from Auto Atlanta and ordered this one: http://www.autoatlanta.com/detail.php?pn=B...E&user=Mike With this MPS, my car drives much better and is definitely more powerful. Unfortunately the car now pops in the exhaust when decelerating. Replace the old MPS again, no more pops but also less power. Any suggestions on next steps? |
mgphoto |
Jul 12 2018, 07:43 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Does the engine has the deaccelaration valve, if so remove it and plug the ports.
MPS may not be tuned for the engine displacement. |
JeffBowlsby |
Jul 12 2018, 08:58 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Lo-Fi Version | Time is now: 7th May 2024 - 03:59 AM |
