Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
Dave_Darling |
Jul 13 2018, 05:28 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The answer is most likely no, but it depends on the 19mm bar you're talking about.
Front bars range from JC Whitney (which I wouldn't use!), through Weltmeister, up to Tarrett and possibly Smart Racing. Generally in increasing order of both quality and cost. The WM ones work, but do not use the "no gas tank removal" installation kit--and it's generally better to weld in the nut plates. --DD |
Lo-Fi Version | Time is now: 13th May 2024 - 11:10 AM |
