Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
914werke |
Jul 13 2018, 05:36 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Are you upgrading or installing new?
HansJan |
Jul 13 2018, 05:42 PM
Are you upgrading or installing new? Installing new. Ordered the mounting brackets (that need to be welded in place) yesterday. There is this fellow "Ian Karr" that post YouTube videos, making it appear to be doable. Now I need to find the correct Sway bar system to use. The car is a 1972-4, with 103mm cylinders. Any advise regarding size, or hollow vs solid bar? |
Lo-Fi Version | Time is now: 13th May 2024 - 01:36 AM |
