Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
TravisNeff |
Jul 13 2018, 09:50 PM
I found some sway bar calculators online and did some number crunching.
The sway bar is 38" long overall, but I believe you are to measure the effective length right behind the lever arm, so I used 36" length. For the lever arms, they are 6", the adjustment rate is about 2.5 to 6". Here are the numbers. This would just be for the sway bar rate, not wheel rate. The stock mounting is about 3.5" to the middle of the strut. I think calculating an extra 3.5 inches in lever arm length should give you the wheel rate? Attached image(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 05:36 PM |
