Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
TravisNeff |
Jul 13 2018, 10:08 PM
The calculator is here. http://www.gtsparkplugs.com/Sway-Bar-Calculator.html
Below is a depiction of what to measure. I updated for wheel rate, I am assuming that we need to add 3.5 inches of A-arm length to get wheel rate. I am sure someone will chime in if I have this wrong (IMG:style_emoticons/default/smile.gif) Oh, stock and turbo sway bars are solid, so the ID is zero. My SRP bar is hollow and has a .120 wall thickness, I am assuming the welt bars are the same wall thickness. Attached image(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 06:42 PM |
