Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
TravisNeff |
Jul 13 2018, 10:32 PM
I will check tomorrow when I pull the welt bar. While they look solid, I believe that is only a solid chunk of metal pressed into the hollow bar for mounting the lever arms.
Here is a pic of my srp bar, you can see what I described above. Attached image(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 06:24 PM |
