Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
TravisNeff |
Jul 13 2018, 10:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I will check tomorrow when I pull the welt bar. While they look solid, I believe that is only a solid chunk of metal pressed into the hollow bar for mounting the lever arms.
Here is a pic of my srp bar, you can see what I described above. Attached image(s) |
jcd914 |
Jul 13 2018, 11:31 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I will check tomorrow when I pull the welt bar. While they look solid, I believe that is only a solid chunk of metal pressed into the hollow bar for mounting the lever arms. Here is a pic of my srp bar, you can see what I described above. I have installed probably 30 or more of them and have 2 here at the house, the Weltmeister bars are solid not hollow. The owner of the shop I worked for was friends with the owner of Automotion and Weltmeister, Tom Green (I think that is the right name) and periodically we did testing and development for him. We had a 24mm Weltmeister sway bar we installed in a few of cars to test it, w 911s and a 914. Too stiff for most applications and the rest of the hardware was going to need upgrading, it never went into production. The SRP bar is a very nice quality bar, well designed and built. Jim |
Lo-Fi Version | Time is now: 12th May 2024 - 05:18 PM |
