Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
TravisNeff |
Jul 14 2018, 12:50 PM
Jim, you are right the welt bar is solid. Also, the lever arm adjustment range is about 3.5 to 7.5 inches.
I redid the calculations for the weltmiester bars as a solid bar instead of hollow. A bit of a bummer. While my new sway bar is like jewelery, it is about the same effective rate as the bar that I just pulled from the car. A CFR bar is starting to look inciting. Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 13th May 2024 - 08:07 AM |
