Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
HansJan |
Jul 16 2018, 03:45 PM
So I ended up buying the hollow SRP kit from Travis.
It comes with an Aluminum backing plate. This would allow an installation without welding in the reinforcement triangle (which I already ordered from 914ltd). Does the brain trust believe that I could use it that way? Or should I stilll weld in the reinforcement triangle (and not use the sandwich plate)? |
Lo-Fi Version | Time is now: 12th May 2024 - 09:18 PM |
