Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
HansJan |
Jul 25 2018, 09:40 PM
JamesM |
Jul 30 2018, 02:07 AM
Senior Member Group: Members Posts: 1,896 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Can any one tell me what size rear suspension I have? Diameter of the coil is 10mm.The spring is 7 windings long. I can tell your rear shocks are terrible. If you are planning on changing the spring rate I would recommending holding off and replacing the rear shocks with a set of Bilsteins first as the ride quality will change drastically. |
Lo-Fi Version | Time is now: 13th May 2024 - 06:38 AM |
