Do stock drop links fit a 19mm sway bar?, Looking to buy drop links from classified section. |
HansJan |
Jul 13 2018, 11:00 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
There is a set of stock drop links in the classified section. Would they fit a 19mm sway bar? Or should the 19mm sway bar be purchased as a set? If so: which set is best for street use (value and quality)? Thanks |
Dave_Darling |
Jul 30 2018, 04:07 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
White shocks are usually KYB, which has gotten a reputation in the 914 world as "Kill Your Back".
As for the spring rate, I can only suggest you remove the springs, and use a scale and some weights to measure how many pounds it takes to compress the springs by a few inches. Divide the pounds by inches and you have the spring rate in inch-pounds... --DD |
Lo-Fi Version | Time is now: 12th May 2024 - 06:53 PM |
