Catching 1st gear, Hard time shifting into 1st |
North Coast Jim |
Jul 14 2018, 05:31 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Car runs great after putting her back together and now have 1800 miles of Fun Fun Fun on her. Wife and I enjoy driving around the island area enjoying the scenery. A couple of trips to Stoddard's and a run to Mid Ohio for the IMSA races and the car runs great except for one issue.
Tranny rebuilt by Dr Evil and all shifter bushings were replaced. When attempting to get the car into first gear the selection if very hard and is hard to locate. All other gears are easy to locate and car shifts fine otherwise. Have had to resort to putting the car into 1st gear while it still rolling as that helps to get it into gear. Waiting at the light then requires me to stand on the clutch until ready to launch. Tried to rotate the shift linkage one tooth right and then left and all that did was cause issues with other gear selections. It's back to where it was originally I did not rebuild the shifter mechanism in the car as it seemed to be Ok at the time. Is this my problem ?? Is this normal for a 914 or is there something else I should be looking into. This is our second 914 in my life and I don't remember this being a problem back in 1980 but of course that was along time ago. Appreciate any help. |
ConeDodger |
Jul 14 2018, 06:37 PM
Apex killer! Group: Members Posts: 23,543 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Shift linkage adjustment sounds in order.
Mike Bellis |
Jul 14 2018, 10:08 PM
Or clutch cable adjustment. As the age, they stretch... Usually right before they break...
Mikey914 |
Jul 15 2018, 01:09 AM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Is reverse also difficult to engage also? I suspect clutch.
wndsrfr |
Jul 15 2018, 06:37 AM
Senior Member Group: Members Posts: 1,427 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Is reverse also difficult to engage also? I suspect clutch. (IMG:style_emoticons/default/agree.gif) Both of mine are bitchy getting into first when sitting still...suspect that I still need to tighten the clutch cable bit. A good test is to get it warmed up, (remember that the cable will grow a bit when hot) put it in neutral, foot off clutch, then push the clutch all the way to the floor, count two seconds and try reverse. If it grinds, you need to tighten the clutch cable a bit & try again.... |
tsvo |
Jul 15 2018, 07:24 AM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I had similar issues and adjusting the clutch cable helped quite a bit.
Mikey914 |
Jul 15 2018, 04:41 PM
The cable will stretch if ground cable is not making good contact. So if it needs readjusting again shortly after, chec5the ground strap.
Lo-Fi Version | Time is now: 28th March 2024 - 05:17 AM |
