Rear Trailing Arm bushing question, Rear Trailing Arm bushing question!!! |
914pipe |
Jul 14 2018, 09:42 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
I was working on my car today and notice horizontal movement on my rear trailing arms... Just want to confirm that the bushings are shot!!!
Here is a video, and please recommendations are welcome! https://youtu.be/LPdmE-0kGqk Thanks!!! |
76-914 |
Jul 14 2018, 09:51 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yep, shot to shit. If you have access to a bench press and another pair of arms go back with OEM Rubber. Otherwise, go needle bearing or poly bushings. (IMG:style_emoticons/default/beerchug.gif)
914pipe |
Jul 14 2018, 09:53 PM
Yep, shot to shit. If you have access to a bench press and another pair of arms go back with OEM Rubber. Otherwise, go needle bearing or poly bushings. (IMG:style_emoticons/default/beerchug.gif) Thanks!!! |
Mike Bellis |
Jul 14 2018, 10:07 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
When is McMark going to offer needle bearings again?
914pipe |
Jul 14 2018, 11:24 PM
There was a thread from Erick Shea and how to install these but the link is not working... Does anyone have a step-by-step for this?
Mueller |
Jul 14 2018, 11:59 PM
That looks like an elongated mounting hole to me and not a worn bushing.
Doesn't Tangerine Racing make a kit that repairs that? |
Porschef |
Jul 15 2018, 09:11 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
914pipe |
Jul 15 2018, 09:15 AM
That looks like an elongated mounting hole to me and not a worn bushing. Doesn't Tangerine Racing make a kit that repairs that? Hard to see, but the nut on the shaft doesn't appear to be moving much, I'd think it's the bushing Exactly, the nut is not moving. |
914forme |
Jul 15 2018, 09:25 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
If you find an elongated hole it is an easy fix. Weld a washer to the outside. Where you want the shaft to be, and the fill in the back side with a bit of weld. Next drill out the hole, problem solved.
You can also machine out a piece that fits into the hub, machine the hub, and then weld the assembly. Or you can buy Chris pieces and do it right Tangerine Racing. As far as bushing goes I would upgrade all my stuff to needles if someone would produce them again. Run Elephant Poly Bronze on the EG build and Rebel Racing is going on the 914-6. I find as long as the bushings are not binding the do not add to the harness of the ride. |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:14 AM |
