Brake master cylinder feed lines |
raynekat |
Jul 15 2018, 12:14 AM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Has anyone tried to restore these?
914 Rubber sells the lines (can't find the listing), but they are unbent and I have no idea how you'd ever get these lines onto a set of original metal ends? Do you heat the lines until melting? How would you actually pull the plastic lines onto the metal ends? Even if you got the lines on the metal ends, how would you shape the straight plastic lines into the correct curves? Any thoughts on these? The new factory parts which have black plastic lines are like $140 each! |
jmitro |
Jul 15 2018, 05:36 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I bought mine from PMB. they were straight also. I just used them straight, and they are very difficult to wedge onto the hard metal lines. In retrospect I would just use soft lines from the reservoir to MC.
Heating them does NOT make it easier to install the metal lines |
Lo-Fi Version | Time is now: 15th May 2024 - 11:55 AM |
