Frustrated in Louisville |
dabird |
Jul 16 2018, 07:48 AM
Member Group: Members Posts: 94 Joined: 17-October 14 From: New Albany, IN Member No.: 18,025 Region Association: None |
I'm making this post just for a little motivation. I bought this 74 2.0 a few years ago and have only driven it around the block once. Immediately replaced the fuel lines and then had the rear calipers rebuilt by PMB. Finally got those installed last summer and before I even bleed the brakes I noticed a leaking fuel injector. I walked out to the garage today and thought " I should probably get this thing on the road". Life, work, kids etc have put the car on the back burner but sitting in it this morning made me want to give it a little more attention. The fuel injector leak, bleeding/adjusting the rear calipers and a broken garage door are pretty much the only things keeping me from giving it a proper shakedown run. I'm hoping posting about this car will be the first step towards making it a little more of a priority to not let such a cool vehicle languish in my tiny garage.
Attached thumbnail(s) |
dabird |
Jul 17 2018, 01:06 PM
Went out to the garage just now because I wanted to which injector was leaking. I also thought hearing the car run a few seconds would get me motivated. Well, that plan backfired. Couldn't get it to start... just cranks. Added some fresh gas .. just cranks... now I've had plenty of German cars that wouldn't start.. pretty much every Scirocco I ever owned ( and I've owned a handful) so it's not the end of the world ... just another bummer in the saga of 914 ownership. Pretty sure I can hear the relay click but I'm not hearing the pump run for a second or two... anyone have a quick rundown on how to test the pump?
Unobtanium-inc |
May 26 2019, 10:51 PM
Advanced Member Group: Members Posts: 2,210 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Went out to the garage just now because I wanted to which injector was leaking. I also thought hearing the car run a few seconds would get me motivated. Well, that plan backfired. Couldn't get it to start... just cranks. Added some fresh gas .. just cranks... now I've had plenty of German cars that wouldn't start.. pretty much every Scirocco I ever owned ( and I've owned a handful) so it's not the end of the world ... just another bummer in the saga of 914 ownership. Pretty sure I can hear the relay click but I'm not hearing the pump run for a second or two... anyone have a quick rundown on how to test the pump? Scirocco's can be a nightmare, my first car was an 82! Concerning your car, one trick that works for a lot of guys, me included, is set a goal when you want it roadworthy, like an event six months from now. I know lots of 356 guys that do this with the annual 356 Registry holiday, which is normally in the fall, starting in the winter they start cranking away. Since their is a goal it makes the time count. Like a normal Saturday, you're thinking, is it worth getting greasy for a couple of hours, if you have a goal anything more an an hour becomes a yes. Good luck. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:43 PM |
