Parts wanted, buncha small early items |
VintageExcellence |
Jul 16 2018, 10:24 AM
Member Group: Members Posts: 52 Joined: 27-August 04 From: San Diego, CA Member No.: 2,636 |
Missing a few small hardware items for my early 914-6. All these parts would be for a very early 1/70 build car and I am only looking for excellent quality parts not junk please.
1. x1 headlight pivot 3 screw, the early ones are steel and a magnet will stick to them (not pot metal), they have a pointed shaft Found these **2. x10 headlight pivot allen bolts, these are the very short M6 allen that mount the pivot arms to the chassis. Not sure why I am missing all of these but I can't seem to find them in my hardware - can anyone post a pic of the size of these things? I have the mounting plates and washers. 3. Black plastic battery cover, the one held down by the O-ring, anyone know what size battery is correct for a 914-6? Found these** 4. Fuel tank rubber blocks, the ones on the outside left and right Found this** 5. x1 trailing arm bolt, these are M10x55mm with a 10.9 grade 6. LEFT early defrost vent, goes on top of the air flap in the trunk, I have one with a broken plastic mounting stud, I want one with no cracks or broken off parts Found this**7. Strut top forward mount - pictured below, I just need x1 of the front mounts Found this** 8. Spare tire hold down washer, I have the stud but no washer Attached thumbnail(s) |
VintageExcellence |
Jul 16 2018, 10:26 AM
1. x1 headlight pivot 3 screw, the early ones are steel and a magnet will stick to them (not pot metal), they have a pointed shaft picture of the early part Attached thumbnail(s) |
VintageExcellence |
Jul 16 2018, 12:55 PM
Here is a picture of the trailing area bolt I need, one broke coming out.
I like original hardware Attached thumbnail(s) |
VintageExcellence |
Jul 16 2018, 12:58 PM
left defrost vent, see the broken plastic tab, I need one with no broken tabs
Larmo63 |
Jul 16 2018, 06:50 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I have a battery thingie.
KevinW |
Jul 16 2018, 07:47 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I have the fuel tank rubber blocks, spare tire hold down washer and the strut top forward mount.
KevinW |
Jul 16 2018, 08:05 PM
Headlight pivot Allen bolts
KevinW |
Jul 16 2018, 08:17 PM
Found a couple of trailing arm bolts
Mikey914 |
Jul 17 2018, 07:56 PM
The rubber man Group: Members Posts: 12,640 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
disregard I mis-read
carl k |
Jul 19 2018, 06:36 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
VintageExcellence |
Aug 20 2018, 09:29 AM
Still looking for the L defrost vent with no broken tabs and a original black plastic battery cover.
Carl, sent you an email on the headlight pivot. |
Lo-Fi Version | Time is now: 29th April 2024 - 11:19 AM |
