Oil Bath...Oil, Type of Oil |
Ross |
Jul 17 2018, 08:03 AM
Member Group: Members Posts: 90 Joined: 17-August 16 From: Charlotte, NC Member No.: 20,304 Region Association: South East States |
RE: 914 1972 1.7
Hi Guys, Do you all know the type of oil used for the oil bath? Thanks in advance for the help, Ross |
76-914 |
Jul 17 2018, 08:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
In the old days we used the old oil after an oil change. This wasn't on Porche's so wait for an informed answer. (IMG:style_emoticons/default/beerchug.gif)
bretth |
Jul 17 2018, 09:54 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I believe the manual for my 68 bus said 30 weight oil. I assume it is the same for early 914s too.
stevend914 |
Jul 17 2018, 11:48 AM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
RE: 914 1972 1.7 Hi Guys, Do you all know the type of oil used for the oil bath? Thanks in advance for the help, Ross Check this: http://type2.com/library/body/baroil.htm |
Jul 17 2018, 12:25 PM
Motor oil. Same stuff you put in the engine, because it will be convenient and to hand. It also saves you from having to keep track of (very slightly) different oils for different purposes when those differences aren't actually needed.
--DD |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:58 PM |
