1975 914-4... is it worth $$$? |
bwaz |
Jun 13 2005, 05:43 PM
Newbie Group: Members Posts: 4 Joined: 13-June 05 From: vancouver Member No.: 4,271 |
Hi there, new to the 914 as my neighbour has one sitting in his backyard and is wanting to sell it. It's a 1974 4-cyl (1.8 or 2 litre?) has had some rust work done on the pans but has been sitting for nearly 10 years. Has Fuchs and supposedly a 911 suspension mod done to it. Some rust underneath and on surface of body, interior in pieces, rolls but don't want to try and start it! What's it worth?
$500, $1000 or $5000? thanks for your help! Bwaz |
Mueller |
Jun 13 2005, 05:48 PM
from your description, $500 max.....detailed pictures would be best, but chances are the car has suffered too many years of neglect.....
street legal go-kart |
Miss Mari's slave Group: Members Posts: 437 Joined: 28-March 03 From: sierra nevada ,cali . Member No.: 490 |
Pictures?
Allan |
Jun 13 2005, 06:46 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Yep, pics first, answers later..... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
bwaz |
Jun 15 2005, 11:49 PM
I know, I know, bad pics, but that's all I can get until I pull it out of its hole this weekend!
thanks for any thoughts Brian Attached image(s) |
Dead Air |
Jun 16 2005, 12:08 AM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
It's not a '74. Might be a 2.0. If it were a 2.0!.... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
you could get $400 for the engine and $400 for the wheels!!Easy! Confirm? |
jet1 |
Jun 16 2005, 12:22 AM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
That's how mine looked when I went to look at it for the first time.(stuffed in an old barn/garage) I spent a whole day cleaning out the mouse crap.
GWN7 |
Jun 16 2005, 12:24 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
75 or 76 bumpers on it...... when you get it dug out take pics of the "hell hole" and the suspension mounts/longs
If you can read the serial number you can tell what yr it is |
bwaz |
Jun 16 2005, 01:31 PM
Hi again, thanks for all the help. I'm fairly new to 914's, so exactly where is the "hell hole" and the suspension mounts/longs? Shock towers? thanks again, i'll check for the 3 bolts to see if it's a 2.0
Brian |
redshift |
Jun 16 2005, 01:36 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Open the engine lid, and look down the passenger side, under the battery tray, all the way in that pass side low corner.
Poke with a screwdriver. M |
jet1 |
Jun 16 2005, 05:56 PM
The longs are the Longitudinals. look behind the rocker panels and around the jack points. Do a search in the fourm for hell hole and rust repair before you buy anything. 914's can look good from the outside, but be rust buckets under the surface. Here is a photo of a Longitudinal. the driver side is usually not as bad as the passenger side. As far as the suspension mounts go, just check all around the rear suspension for any signs of rust. Also, look under the carpet and behind the seats. It's best to take your time and give the car a really good look.
Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:57 PM |
