WTB Relief valve piston and spring in use-able condition, Relief valve piston and spring |
renaultc |
Jul 19 2018, 12:27 PM
Newbie Group: Members Posts: 13 Joined: 18-February 13 From: Regina, sk Member No.: 15,548 Region Association: Canada |
914Sixer |
Jul 19 2018, 01:56 PM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I should have one, but finding it might be the trick. I will look in the morning. 106 degrees right now.
KevinW |
Jul 19 2018, 02:15 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I have both
ClayPerrine |
Jul 19 2018, 02:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Go to Tangerine racing website and order the kit to replace it. 40+ years of use has worn the bore, and with it comes low oil pressure. Chris has created a kit to fix it. Simple installation. It too me 30 minutes, and most of that was putting the car on jack stands and letting it down.
renaultc |
Jul 19 2018, 02:44 PM
renaultc |
Jul 19 2018, 02:45 PM
Go to Tangerine racing website and order the kit to replace it. 40+ years of use has worn the bore, and with it comes low oil pressure. Chris has created a kit to fix it. Simple installation. It too me 30 minutes, and most of that was putting the car on jack stands and letting it down. The bore is good, I was hoping to locate a good used one. If I can't then this is the way I'll be going. Thanks for the tip. Appreciated. |
renaultc |
Jul 19 2018, 02:47 PM
I should have one, but finding it might be the trick. I will look in the morning. 106 degrees right now. Thanks Mark. KevinW might have one for me. If he doesn't then I'll get in touch. Stay cool and drink (IMG:style_emoticons/default/beer3.gif) not even close to 106 at all in the north. something like 26C here today in Regina. city that rhymes with fun. |
914Sixer |
Jul 19 2018, 07:30 PM
Didn't have one. Large one only.
Lo-Fi Version | Time is now: 4th May 2024 - 03:13 PM |
