FS : Zenith 40 T I N carburetors & manifolds, Taken off 911T engine |
Dion |
Jul 23 2018, 05:52 PM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Asking $1,400
These carbs came off a 911T engine. I’m no carb expert but I gently “cleaned” them and replaced the all the gaskets that came in a Zenith kit. Some mods done to the manifold per previous owner Quote: “The ports and lines you see are there to supply manifold vacuum for the power assisted brakes on the VW camper in which I had the engine installed .. You can just plug those off .. Tap and install pipe plugs or maybe a 6 or 8-MM bolt ..or just use rubber caps... The other plugs you see are for the emission controls those carbs originally came with .. Their function was to keep the engine from dropping back to dead idle ( throttle plates closing ) This created a high vacuum situation where there was fuel being drawn into the cylinders and having no coming in for O2 for combustion to take place .. That whole system has been removed and the necessary passages plugged” I removed the fuel lines and vacuum hoses as they were dry rotted. These should be ready to just bolt on and go once the appropriate adjustments made. NO air filter or housings included PayPal Thanks. US shipped only Attached thumbnail(s) |
Dion |
Jul 23 2018, 05:54 PM
Pics
Dion |
Pics
Dion |
Jul 23 2018, 05:55 PM
Pics
Dion |
Jul 23 2018, 05:56 PM
Overhead
forrestkhaag |
Jul 23 2018, 06:30 PM
Good detail in your pics / good luck with your sale / the right car and engine needs this setup
cheers (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/icon_bump.gif) |
Dion |
Jul 23 2018, 08:29 PM
Extra pics: old vacuum lines highlighted in yellow block since removed.
johnhora |
Jul 24 2018, 08:50 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Dion...
Be sure to post these over on Pelican and 911 Registry sites.. Many 911 owners there that would be interested in these.. Good luck on the sale...nice carbs |
Dion |
Jul 24 2018, 08:58 AM
Dion |
Jul 31 2018, 05:24 AM
Price Reduced $1,400. (IMG:style_emoticons/default/smash.gif)
Dion |
Aug 13 2018, 07:04 AM
I will certainly entertain reasonable offers (shipping not included) (IMG:style_emoticons/default/smash.gif)
My 914 will appreciate your contribution to its resto. (IMG:style_emoticons/default/beerchug.gif) Pass the word. Thanks guys. Appreciate you looking. |
Dion |
Aug 27 2018, 09:21 AM
Now $1,200 + S & H
Thanks for checking. |
bdstone914 |
Aug 28 2018, 08:04 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You will probably have better luck selling them on Early 911S Registry to some one who has a car on which those are correct. Not knocking the price but those type carbs were selling for $300 a few years ago. But then again people used to junk the original Solex 3 barrel carbs now 911 owners are paying up to $6000 for a set as the supply dries up.
Dion |
Aug 28 2018, 05:28 PM
Bruce, I have them on the S registry & Pelican.
I was basing my price on evilbay. Most are asking this price for 1 instead of the pair. If you know anyone..... I’m open to offers. Just had to start a price somewhere. Thanks looking in. |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:19 PM |
