Charging question on a 914-6 |
db9146 |
Jul 28 2018, 08:11 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Well, I have made a temporary conversion of my -6, inserting a rebuilt 2.7S with ITBs, MS3, and distributorless ignition in place of the tired 2.0L. Before putting the engine in, I decided it best to install a new alternator along with a new engine/alternator wiring harness.
The alternator is for a 1965-1977 911 2.0-2.7 that uses an external VR. and here's the new wiring including a new ground strap to the engine case. The large red cable goes to the starter, the smaller red wire is D+, the black is DF, and brown is D-. I thought the problem might be the battery because of its age but when I checked the output of the charging system at the battery, there was none. I replaced some of the dash lights with LEDs but made sure not to replace the GEN warning light, which is not coming on despite the alternator not charging. Should I next pull the D+, DF, and D- plug and check for alternator output across DF and D+ momentarily? If there is output, what then? If not, what's next? |
db9146 |
Jul 31 2018, 12:39 PM
Last night, I measured the voltage at the battery again with it fully charged before I started. It was 12.8V. I turned the key (GEN light came on), then started it up (rev'ed it and GEN light went off) and measured the voltage at the battery again - no change.
I then replaced the VR with a "new" old VR that I just recently bought and measured the voltage again. This time it was about 13.15 at an elevated idle. So now it seems like its charging but not much, so I checked the chassis strap to the trans. I removed the nuts and strap, checked that the area was as clean as I thought, and reattached the new strap in between. I then moved to the ground strap connection for the battery. Before I installed the new engine, I repaired the ground stud which the PO had twisted off, cleaned up the area, and installed the new battery ground strap. Everything looked good and was tight here. Even with this, I checked the battery voltage again and got 13.10, slightly less than I had measured before removing, checking, and reinstalling the trans ground strap. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:09 AM |
