Charging question on a 914-6 |
db9146 |
Jul 28 2018, 08:11 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Well, I have made a temporary conversion of my -6, inserting a rebuilt 2.7S with ITBs, MS3, and distributorless ignition in place of the tired 2.0L. Before putting the engine in, I decided it best to install a new alternator along with a new engine/alternator wiring harness.
The alternator is for a 1965-1977 911 2.0-2.7 that uses an external VR. and here's the new wiring including a new ground strap to the engine case. The large red cable goes to the starter, the smaller red wire is D+, the black is DF, and brown is D-. I thought the problem might be the battery because of its age but when I checked the output of the charging system at the battery, there was none. I replaced some of the dash lights with LEDs but made sure not to replace the GEN warning light, which is not coming on despite the alternator not charging. Should I next pull the D+, DF, and D- plug and check for alternator output across DF and D+ momentarily? If there is output, what then? If not, what's next? |
db9146 |
Jul 31 2018, 02:35 PM
MH and Spoke, I had started my last post earlier this afternoon and got interrupted by work....go figure.
Anyway, I did install a new Bosch AGM battery so these measurements are with it. The VR is an NOS Bosch metal can unit but I'm seriously contemplating a new SS one or even one of the variable VRs but I want to determine that everything is really okay before I go to an adjustable VR and cover up the symptom (lower charging voltage). |
Lo-Fi Version | Time is now: 19th May 2024 - 10:08 AM |
