Charging question on a 914-6 |
db9146 |
Jul 28 2018, 08:11 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Well, I have made a temporary conversion of my -6, inserting a rebuilt 2.7S with ITBs, MS3, and distributorless ignition in place of the tired 2.0L. Before putting the engine in, I decided it best to install a new alternator along with a new engine/alternator wiring harness.
The alternator is for a 1965-1977 911 2.0-2.7 that uses an external VR. and here's the new wiring including a new ground strap to the engine case. The large red cable goes to the starter, the smaller red wire is D+, the black is DF, and brown is D-. I thought the problem might be the battery because of its age but when I checked the output of the charging system at the battery, there was none. I replaced some of the dash lights with LEDs but made sure not to replace the GEN warning light, which is not coming on despite the alternator not charging. Should I next pull the D+, DF, and D- plug and check for alternator output across DF and D+ momentarily? If there is output, what then? If not, what's next? |
larryM |
Aug 15 2018, 09:39 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
p.s. - long ago i acquired some 911 engines & -6 stuff where the p.o. solved the 'engine drop" problem by cutting a large hole in the back of the shroud so he could get at the alternator wires - then he just made a nice grommeted rectangular patch & screwed it over the hole
(depends on how desperate one is & how much time & what shop resources one has, eh?) i eventually threw that shroud away but i did keep the air duct for the oil cooler (3.2 has a removable duct which makes things much easier) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:51 AM |
