1971, Can’t get hood open |
milwlandrover |
Jul 29 2018, 07:29 AM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
Cable must have come off. Removed bumper and found this
Attached thumbnail(s) |
Jul 29 2018, 07:37 AM
914-6 GT in waiting Group: Members Posts: 19,266 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Take off little rubber plug in middle of triangle. (Must have been painted over). Insert flat blade screwdriver and wiggle/trust. Hood should pop.
It’s really important to lube all cables, latches, licks and hinges. Excessive force on any part causes problems. It’s easy to pull the flap off the outer door latch if you have to use force to open the door. Same with winding up the windows. Everything on our cars should be smooth and easy to pull. |
milwlandrover |
Jul 29 2018, 07:41 AM
Awesome just bought yesterday and couldn’t add gas
Had to tow it home Attached thumbnail(s) |
Lo-Fi Version | Time is now: 13th May 2024 - 09:00 AM |
