Need touch up paint and weird brake problem., Arctic Blue? |
914 jackie |
Jul 31 2018, 09:52 PM
Newbie Group: Members Posts: 15 Joined: 18-May 15 From: manhattan beach, ca Member No.: 18,739 Region Association: Southern California |
In need of, I think it's called Arctic Blue touch up paint.
Maybe a gallon or 2 (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) Not really, but more than a pen if possible. Where in the heck can you get it? As for the weird brake issue, they are fine except when I've been on the freeway for a while, then they go to the floor! Staying on surface streets works, but I'd like to know what's up. Anyone else ever have this problem? Thanks, as always, you guys are the best! |
Cairo94507 |
Aug 1 2018, 07:23 AM
Michael Group: Members Posts: 9,741 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Adriatic Blue possibly? (One of my all time favorite colors on a 914.)
jonferns |
Aug 1 2018, 08:02 AM
The paint code should be on a tag in the drivers door jamb. You can visit a local automotive paint shop for touchup paint, or sites like automotivetouchup.com
JFJ914 |
Aug 1 2018, 08:41 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
In need of, I think it's called Arctic Blue touch up paint. Maybe a gallon or 2 (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) Not really, but more than a pen if possible. Where in the heck can you get it? As for the weird brake issue, they are fine except when I've been on the freeway for a while, then they go to the floor! Staying on surface streets works, but I'd like to know what's up. Anyone else ever have this problem? Thanks, as always, you guys are the best! I had the same problem recently, dragging left rear brake caliper causing fluid to boil. See if your wheels turn freely. |
JOEPROPER |
Aug 1 2018, 10:29 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
In need of, I think it's called Arctic Blue touch up paint. Maybe a gallon or 2 (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) Not really, but more than a pen if possible. Where in the heck can you get it? As for the weird brake issue, they are fine except when I've been on the freeway for a while, then they go to the floor! Staying on surface streets works, but I'd like to know what's up. Anyone else ever have this problem? Thanks, as always, you guys are the best! I had the same problem recently, dragging left rear brake caliper causing fluid to boil. See if your wheels turn freely. (IMG:style_emoticons/default/agree.gif) |
76-914 |
Aug 1 2018, 02:24 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
mark04usa |
Aug 1 2018, 03:11 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
For paint, try ExpressPaint.com I've used their rattle can paint, and it matched my L21E Tangerine color and worked well to touch up over repairs.
mgphoto |
Aug 1 2018, 05:08 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Your brakes have air in the hydrolic lines, bleed the brakes really good, including the proportioning valve.
And your rear brake venting clearance is too big. Bleed and adjust, you'll be happy. |
Aug 1 2018, 09:49 PM
Resident German Group: Admin Posts: 41,628 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I had the same problem recently, dragging left rear brake caliper causing fluid to boil. See if your wheels turn freely. (IMG:style_emoticons/default/agree.gif) Dragging brake caliper on one of the corners or maybe even a stuck parking brake. (IMG:style_emoticons/default/driving.gif) PS: Adriatic Blue would be paint code L50E, the paint code should be on the small black plate mounted on the inside of the drivers side door jamb. (IMG:http://www.914world.com/bbs2/uploads/post-179-1217494641.jpg) |
Lo-Fi Version | Time is now: 11th May 2024 - 01:24 PM |
