> HO campaign, caution!
dr914@autoatlanta.com
post Aug 3 2018, 08:43 AM
rhodyguy
post Aug 3 2018, 09:24 AM
What does HO stand for? (IMG:style_emoticons/default/confused24.gif)
Coastal6
post Aug 3 2018, 09:37 AM
QUOTE(rhodyguy @ Aug 3 2018, 08:24 AM) *
Horrible outcome. (IMG:style_emoticons/default/smile.gif)
Tom_T
post Aug 3 2018, 10:51 AM
TMI....
QUOTE(Coastal6 @ Aug 3 2018, 08:37 AM) *
All -
Well that was certainly the result after an engine fire due to battery acid corroded OE cloth-covered fuel lines, but I doubt that was what Porsche had in mind! (IMG:style_emoticons/default/biggrin.gif)
I'm adding the recall info below, because it's important to all members & all vehicle owners, regarding recalls - but first....
As Jeff said, it's the "HO Recall" required by NHTSA for all 70-76 914s, & if yours was never done, then Porsche/PCNA is still required to do them today.
In fact, this is the case for any open recall on any car make & model no matter how old, if never done & documented. That's the USA Federal Law, & I'd imagine it's the same in other countries too.
Just contact PCNA. They'll probably ask you to bring it to a dealer - or send someone out if not running, in order to verify that it was never done.
I know this for a fact, because I went through the process on my own 73 914-2.0, & have my letter from PCNA to contact them & bring it in to a local dealer to have it done, whenever I have it running & registered again, since the PCNA District Manager already came out to my house to verify it.
This is VERY important for ALL of you folks cars - so don't let the local dealership BS you, they do have to do all recall work if never done, but you may have to go to the car manufacturer &/or NHTSA to push the issue through.
So check all of your cars for open recalls - the newer ones with the later VIN code format (1980's started) can be done with the NHTSA Recall Look-up using your VIN. For older vehicles with the older you'll have to send an email or postal inquiry to NHTSA, then follow-up with the dealer(s) &/or manufacturer(s) to get them set-up & done.
Jeff's website lists the 914 ones -
http://bowlsby.net/914/Classic/Recalls.htm
NHTSA Recall Look-up -
https://www.nhtsa.gov/recalls
Cheers! (IMG:style_emoticons/default/beerchug.gif)
Tom
dr914@autoatlanta.com   HO campaign   Aug 3 2018, 08:43 AM
rhodyguy   What does HO stand for? :confused:   Aug 3 2018, 09:24 AM
sithot   What does HO stand for? :confused: H.O. trains,...   Aug 3 2018, 09:37 AM
Coastal6   What does HO stand for? :confused: Horrible outc...   Aug 3 2018, 09:37 AM
sithot   What does HO stand for? :confused: Horrible out...   Aug 3 2018, 09:43 AM
Tom_T   What does HO stand for? :confused: Horrible out...   Aug 3 2018, 10:51 AM
dr914@autoatlanta.com   Tom is dead on, if your 914 has not had it done, t...   Aug 3 2018, 11:29 AM
ejm   As Jeff said, it's the "HO Recall" ...   Aug 3 2018, 08:12 PM
rhodyguy   A little baking soda sprinkled on the bat tray wit...   Aug 3 2018, 09:47 AM
Jeff Bowlsby   You guyzzz.. :rolleyes: HO is the 914 recall cam...   Aug 3 2018, 10:08 AM
rhodyguy   Nice jeff. 2 lugs with green paint. Who knew?   Aug 3 2018, 10:22 AM
bbrock   2 lugs with green paint. Who knew? Don't ge...   Aug 3 2018, 10:30 AM
914Next   2 lugs with green paint. Who knew? Don't g...   Aug 4 2018, 08:01 AM
dr914@autoatlanta.com   green slathered 914 alloy wheel lug nuts are a sig...   Aug 4 2018, 08:32 AM
914Next   green slathered 914 alloy wheel lug nuts are a si...   Aug 4 2018, 09:47 AM
dr914@autoatlanta.com   we have them on the shelf, 111601173 [quote nam...   Aug 4 2018, 09:59 AM
Jeff Bowlsby   George where can one buy the black lug covers? ...   Aug 4 2018, 10:09 AM
dr914@autoatlanta.com   Jeff is of course correct, as usual, in that they ...   Aug 4 2018, 11:06 AM
Lucky9146   George can't catch a break so I will say i...   Aug 3 2018, 11:04 AM
bbrock   So back to this sticker. The placement seems wron...   Aug 3 2018, 04:07 PM
dr914@autoatlanta.com   SHOULD be on the battery cover, but never know wha...   Aug 3 2018, 04:30 PM
bbrock   SHOULD be on the battery cover, but never know wh...   Aug 3 2018, 07:23 PM
rhodyguy   Those are beautiful wheels.   Aug 4 2018, 08:09 AM
r_towle   914 HO you are!   Aug 4 2018, 11:09 AM
- Lo-Fi Version Time is now: 16th January 2026 - 10:04 AM
