| dr914@autoatlanta.com |
Aug 3 2018, 08:43 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,220 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| rhodyguy |
Aug 3 2018, 09:24 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What does HO stand for? (IMG:style_emoticons/default/confused24.gif)
| Coastal6 |
Aug 3 2018, 09:37 AM
Newbie ![]() Group: Members Posts: 47 Joined: 15-March 10 From: Florence, OR Member No.: 11,467 Region Association: Pacific Northwest |
Horrible outcome. (IMG:style_emoticons/default/smile.gif) |
| Tom_T |
Aug 3 2018, 10:51 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
All - Well that was certainly the result after an engine fire due to battery acid corroded OE cloth-covered fuel lines, but I doubt that was what Porsche had in mind! (IMG:style_emoticons/default/biggrin.gif) I'm adding the recall info below, because it's important to all members & all vehicle owners, regarding recalls - but first.... As Jeff said, it's the "HO Recall" required by NHTSA for all 70-76 914s, & if yours was never done, then Porsche/PCNA is still required to do them today. In fact, this is the case for any open recall on any car make & model no matter how old, if never done & documented. That's the USA Federal Law, & I'd imagine it's the same in other countries too. Just contact PCNA. They'll probably ask you to bring it to a dealer - or send someone out if not running, in order to verify that it was never done. I know this for a fact, because I went through the process on my own 73 914-2.0, & have my letter from PCNA to contact them & bring it in to a local dealer to have it done, whenever I have it running & registered again, since the PCNA District Manager already came out to my house to verify it. This is VERY important for ALL of you folks cars - so don't let the local dealership BS you, they do have to do all recall work if never done, but you may have to go to the car manufacturer &/or NHTSA to push the issue through. So check all of your cars for open recalls - the newer ones with the later VIN code format (1980's started) can be done with the NHTSA Recall Look-up using your VIN. For older vehicles with the older you'll have to send an email or postal inquiry to NHTSA, then follow-up with the dealer(s) &/or manufacturer(s) to get them set-up & done. Jeff's website lists the 914 ones - http://bowlsby.net/914/Classic/Recalls.htm NHTSA Recall Look-up - https://www.nhtsa.gov/recalls . Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Aug 3 2018, 11:29 AM
Tom is dead on, if your 914 has not had it done, the Porsche dealer will do it no charge. HOWEVER one has to watch how they do it, as we saw one that was just done within the last three months, and Hennessy Porsche ABSOLUTELY butchered it, cutting uneven lines using serrated hose clamps, and not even installing a battery cover!!! Looked Like a Johnny home butcher repair, could not believe it!
dr914@autoatlanta.com HO campaign Aug 3 2018, 08:43 AM
sithot
What does HO stand for? :confused:
H.O. trains,... Aug 3 2018, 09:37 AM
sithot
Horrible out... Aug 3 2018, 09:43 AM
ejm
As Jeff said, it's the "HO Recall" ... Aug 3 2018, 08:12 PM
rhodyguy A little baking soda sprinkled on the bat tray wit... Aug 3 2018, 09:47 AM
Jeff Bowlsby You guyzzz.. :rolleyes:
HO is the 914 recall cam... Aug 3 2018, 10:08 AM
rhodyguy Nice jeff. 2 lugs with green paint. Who knew? Aug 3 2018, 10:22 AM
bbrock
Don't ge... Aug 3 2018, 10:30 AM
914Next
Don't g... Aug 4 2018, 08:01 AM
dr914@autoatlanta.com green slathered 914 alloy wheel lug nuts are a sig... Aug 4 2018, 08:32 AM
914Next
green slathered 914 alloy wheel lug nuts are a si... Aug 4 2018, 09:47 AM
dr914@autoatlanta.com we have them on the shelf, 111601173
[quote nam... Aug 4 2018, 09:59 AM
Jeff Bowlsby
George where can one buy the black lug covers?
... Aug 4 2018, 10:09 AM
dr914@autoatlanta.com Jeff is of course correct, as usual, in that they ... Aug 4 2018, 11:06 AM
Lucky9146
George can't catch a break so I will say i... Aug 3 2018, 11:04 AM
bbrock So back to this sticker. The placement seems wron... Aug 3 2018, 04:07 PM
dr914@autoatlanta.com SHOULD be on the battery cover, but never know wha... Aug 3 2018, 04:30 PM
bbrock
SHOULD be on the battery cover, but never know wh... Aug 3 2018, 07:23 PM
rhodyguy Those are beautiful wheels. Aug 4 2018, 08:09 AM
r_towle 914 HO you are! Aug 4 2018, 11:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th December 2025 - 11:18 PM |
