5-lug suspension parts 914-6 |
dug |
Aug 4 2018, 02:04 AM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
Must let these parts go to complete other projects...
Complete (minus brakes) 5-lug suspension setup. Super-mega deal to buy it all in one package $3000 plus insured fedex shipping. Individually priced these parts will easily run $4k or more. Located in SF Bay area. Many parts new, many restored, some original 914-6. 914-6 front A-Arms with sway bar tabs, powder coated (use 911 torsion bars) New Elephant racing poly-bronze bushing set New Elephant racing low-friction control arm mounts 914-6 A-arm mounts, powder coated 914-6 cross-member, powder coated Aluminum 911 cross-member 911S Koni front struts with 3.5" caliper mounts (use pinch-bolt type ball joints) Struts modified with raised/gusseted spindles, bent steering arms Bead-blasted front hubs with (10x) 60mm studs Used Koni inserts (rebuild or replace) with correct thread Aluminum dual-offset cambered strut mounts with spherical bearings Factory 914-6 rear trailing arms, powder coated New Elepant polybronze bushing (installed) Factory 914-6 rear hubs Factory 914-6 rear stub-axles You will also need spindle-nuts, tie-rods, pinch-bolt style ball-joints, front and rear wheel-bearings, 3.5" front brake calipers and 911 brake rotors, brake pads, brake lines and rear 5-lug brake rotors. I can advise the buyer on selecting and sourcing these parts as necessary to complete the setup. Plenty of great resources and advice on these forums too. |
dug |
Aug 19 2018, 04:30 AM
Bump. Still available.
I've had some inquiries about breaking the parts up. I will post separate prices tomorrow. Get it all as one package quick before it's gone! (IMG:style_emoticons/default/smile.gif) dug |
mlindner |
Aug 19 2018, 05:38 AM
Senior Member Group: Members Posts: 1,496 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
If your planning to go five bolt hubs, this is a real deal. I did mine two years ago and the cost was much higher. Best, Mark
dug |
Aug 19 2018, 01:49 PM
Sale pending. Thanks 914world!
cheers, dug |
Lo-Fi Version | Time is now: 29th March 2024 - 07:29 AM |
