Fuel Tank Pads:, Product Recommendations |
914_7T3 |
Aug 5 2018, 02:26 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Looking for a replacement solution to the original fuel tank pads that retain moisture and rust the tank from the outside in.
Was thinking about some type of rubber padding that may be used similar to the below. Would also like to line the top of the battery tray with it as well. Any thoughts? Waxman 2-Pack 4-in Black Rubber Pads (w/ adhesive backing) |
bbrock |
Aug 9 2018, 12:53 PM
I know i'm speaking alone here but I have serious doubts that a neoprene pad is solving the problem of moisture being trapped against the tank surface. It is just trapping the moisture it in a different way. If the surface of neoprene or rubber is textured to minimize the contact area with the tank, I think that would be ideal. Another option might be to smear the pads with a sealant just before dropping the tank in to prevent water wicking between the surfaces. It would be easy enough to test a neoprene pad by placing a piece of glass with a little weight on top and then spraying water on the edge so you could see how much wicks under the glass and how long it takes to dry.
Lo-Fi Version | Time is now: 19th May 2024 - 12:21 PM |
