Fuel Tank Pads:, Product Recommendations |
914_7T3 |
Aug 5 2018, 02:26 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,847 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Looking for a replacement solution to the original fuel tank pads that retain moisture and rust the tank from the outside in.
Was thinking about some type of rubber padding that may be used similar to the below. Would also like to line the top of the battery tray with it as well. Any thoughts? Waxman 2-Pack 4-in Black Rubber Pads (w/ adhesive backing) |
bbrock |
Aug 9 2018, 12:53 PM
I know i'm speaking alone here but I have serious doubts that a neoprene pad is solving the problem of moisture being trapped against the tank surface. It is just trapping the moisture it in a different way. If the surface of neoprene or rubber is textured to minimize the contact area with the tank, I think that would be ideal. Another option might be to smear the pads with a sealant just before dropping the tank in to prevent water wicking between the surfaces. It would be easy enough to test a neoprene pad by placing a piece of glass with a little weight on top and then spraying water on the edge so you could see how much wicks under the glass and how long it takes to dry.
raynekat |
Aug 9 2018, 01:08 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I know i'm speaking alone here but I have serious doubts that a neoprene pad is solving the problem of moisture being trapped against the tank surface. It is just trapping the moisture it in a different way. If the surface of neoprene or rubber is textured to minimize the contact area with the tank, I think that would be ideal. Another option might be to smear the pads with a sealant just before dropping the tank in to prevent water wicking between the surfaces. It would be easy enough to test a neoprene pad by placing a piece of glass with a little weight on top and then spraying water on the edge so you could see how much wicks under the glass and how long it takes to dry. I agree completely. If your felt pad, or whatever pad, is getting wet....you've got bigger issues. As long as your trunk seals are in good shape, why would you be getting water in and around where the felt pads lie? That part of your front trunk should be "bone" dry. If not.... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 03:34 PM |
