Converting Oil Temp gauge to Oil Pressure Gauge? |
9144me2enjoy |
Aug 5 2018, 08:34 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
1973 Porsche 914 2.0L. I’m removing my Oil Temp Gauge and installing a Oil Pressure Gauge. I installed a 100 psi VDO Oil Pressure Gauge. Do to the size of the new Sender Unit that fits a 100 psi VDO Gauge you cannot just insert it in the same location in the Taco Plate! I was able to drill a 7/16 hole in the same plate and install the new sender unit. I left the original sender unit where it was at and just removed the plug and placed it on the new 100 psi Oil Pressure Sending Unit. On the other end I just plugged the original harness back in the same 3 prong plug in on the back off the new VDO Oil pressure gauge. Sending unit wire to G and the + to fuse box etc. No reading on gauge! What’s wrong. The new sending unit is extended about 1/2” inside. Any suggestions. Thanks
914forme |
Aug 7 2018, 08:44 AM
My offer taken off the table BTW
Lo-Fi Version | Time is now: 16th May 2024 - 09:38 PM |
