Fuel pump relocation on a 6 |
rgalla9146 |
Aug 5 2018, 08:52 PM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I know this has been covered (and not too long ago) but can't find it.
I'm looking for the proper way to wire a front mounted fuel pump in an original six. I'd rather not run wires from the original rear harness forward. As I recall Dave Darling suggested a proper arrangement. Anyone ? |
914Sixer |
Aug 5 2018, 09:00 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All you need is a switched hot wire and a ground. Find a vacant switched slot on on back of fuse block or install a piggyback plug to a used hot switched wire on the block.
Lo-Fi Version | Time is now: 10th May 2024 - 01:06 AM |
