| Jimz73 |
Aug 6 2018, 06:58 PM
Newbie ![]() Group: Members Posts: 10 Joined: 15-April 03 From: Maumee, Oh. Member No.: 575 |
Okay, I am totally stumped and dumb-founded. My car hasn't run for at least 2 years. I replaced the three port fuel pump with a new 2 port pump. The car is a '73 1.7 with stock fuel injection. I replaced fuel lines in tunnel with stainless steel lines at the same time. Tried to start, just cranked and cranked. It is getting gas to the injectors, but I could not get spark. I replaced the coil with a new one. Pulled lead from distributor and placed near the engine tin. Cranked the engine over, no spark. Car ran fine when I garaged it due to leaking fuel pump. I need help to figure it out. I even tried starting fluid and no go. Hasn't even made an attempt to fire.
Jimz73 I have no spark Aug 6 2018, 06:58 PM
The Cabinetmaker Point Gap closed or corroded, or bad condenser Aug 6 2018, 08:22 PM
Rand Lots of talk about fuel when you indicated it was ... Aug 6 2018, 08:29 PM
marksteinhilber You must confirm that you have 12v to the coil whe... Aug 6 2018, 08:56 PM
Jimz73
You must confirm that you have 12v to the coil wh... Aug 7 2018, 08:29 AM
taylspin46
You must confirm that you have 12v to the coil w... Aug 7 2018, 09:36 AM
Larmo63 Also, look inside the distributor cap at the cente... Aug 6 2018, 09:11 PM
marksteinhilber
Also, look inside the distributor cap at the cent... Aug 6 2018, 09:22 PM
cary I'm with Curt. Just ran into that on Mick... Aug 6 2018, 10:37 PM
Dave_Darling Step 1: Verify that there is no spark An extra s... Aug 6 2018, 11:30 PM
Chris914n6 After 2 years of Obamagas anotherthingBushdidwrong... Aug 6 2018, 11:32 PM
914_teener
After 2 years of Obamagas the injectors are likel... Aug 7 2018, 04:50 PM
Chris914n6
[quote name='Chris914n6' post='2636176' date='Aug... Aug 7 2018, 07:41 PM
914_teener
[quote name='Chris914n6' post='2636176' date='Au... Aug 7 2018, 11:53 PM
ClayPerrine
[quote name='Chris914n6' post='2636452' date='Aug... Aug 8 2018, 10:16 AM
Bartlett 914
[quote name='Chris914n6' post='2636452' date='Au... Aug 8 2018, 10:40 AM
ClayPerrine
I Agree but I think it would have been better if ... Aug 8 2018, 11:07 AM
SirAndy When someone slips in this political BS the admin... Aug 8 2018, 11:18 AM
dr914@autoatlanta.com first make sure that in the crank position you sti... Aug 7 2018, 08:30 AM
taylspin46 Ignition coil gets power from fuse9 via ignition c... Aug 7 2018, 09:41 AM
taylspin46
Ignition coil gets power from fuse9 via ignition ... Aug 7 2018, 09:42 AM
taylspin46 Meant poer to S9 from ign. Switch. Aug 7 2018, 09:48 AM
Jimz73 Thanks to all of you. I checked batteries in my me... Aug 7 2018, 11:02 AM
Chris914n6 Also let it run 10-30 minutes to clean the old gas... Aug 7 2018, 01:50 PM
The Cabinetmaker What did you gap the points at. Fsm says to set dw... Aug 7 2018, 02:01 PM
cary Well done ..................
Don't forget to ... Aug 7 2018, 11:56 PM
Jimz73
Don't forget to... Aug 8 2018, 06:46 AM
cary I was meaning all the rest of the lines. The rubbe... Aug 8 2018, 07:17 AM
ClayPerrine I would look into an electronic ignition to replac... Aug 8 2018, 11:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:58 AM |
