> I have no spark, No Spark
Jimz73
post Aug 6 2018, 06:58 PM
Post #21
Okay, I am totally stumped and dumb-founded. My car hasn't run for at least 2 years. I replaced the three port fuel pump with a new 2 port pump. The car is a '73 1.7 with stock fuel injection. I replaced fuel lines in tunnel with stainless steel lines at the same time. Tried to start, just cranked and cranked. It is getting gas to the injectors, but I could not get spark. I replaced the coil with a new one. Pulled lead from distributor and placed near the engine tin. Cranked the engine over, no spark. Car ran fine when I garaged it due to leaking fuel pump. I need help to figure it out. I even tried starting fluid and no go. Hasn't even made an attempt to fire.
Jimz73   I have no spark   Aug 6 2018, 06:58 PM
The Cabinetmaker   Point Gap closed or corroded, or bad condenser   Aug 6 2018, 08:22 PM
Rand   Lots of talk about fuel when you indicated it was ...   Aug 6 2018, 08:29 PM
marksteinhilber   You must confirm that you have 12v to the coil whe...   Aug 6 2018, 08:56 PM
Jimz73   You must confirm that you have 12v to the coil wh...   Aug 7 2018, 08:29 AM
taylspin46   You must confirm that you have 12v to the coil w...   Aug 7 2018, 09:36 AM
Larmo63   Also, look inside the distributor cap at the cente...   Aug 6 2018, 09:11 PM
marksteinhilber   Also, look inside the distributor cap at the cent...   Aug 6 2018, 09:22 PM
cary   I'm with Curt. Just ran into that on Mick...   Aug 6 2018, 10:37 PM
Dave_Darling   Step 1: Verify that there is no spark An extra s...   Aug 6 2018, 11:30 PM
Chris914n6   After 2 years of Obamagas anotherthingBushdidwrong...   Aug 6 2018, 11:32 PM
914_teener   After 2 years of Obamagas the injectors are likel...   Aug 7 2018, 04:50 PM
Chris914n6   [quote name='Chris914n6' post='2636176' date='Aug...   Aug 7 2018, 07:41 PM
914_teener   [quote name='Chris914n6' post='2636176' date='Au...   Aug 7 2018, 11:53 PM
ClayPerrine   [quote name='Chris914n6' post='2636452' date='Aug...   Aug 8 2018, 10:16 AM
Bartlett 914   [quote name='Chris914n6' post='2636452' date='Au...   Aug 8 2018, 10:40 AM
ClayPerrine   I Agree but I think it would have been better if ...   Aug 8 2018, 11:07 AM
SirAndy   When someone slips in this political BS the admin...   Aug 8 2018, 11:18 AM
dr914@autoatlanta.com   first make sure that in the crank position you sti...   Aug 7 2018, 08:30 AM
taylspin46   Ignition coil gets power from fuse9 via ignition c...   Aug 7 2018, 09:41 AM
taylspin46   Ignition coil gets power from fuse9 via ignition ...   Aug 7 2018, 09:42 AM
taylspin46   Meant poer to S9 from ign. Switch.   Aug 7 2018, 09:48 AM
Jimz73   Thanks to all of you. I checked batteries in my me...   Aug 7 2018, 11:02 AM
Chris914n6   Also let it run 10-30 minutes to clean the old gas...   Aug 7 2018, 01:50 PM
The Cabinetmaker   What did you gap the points at. Fsm says to set dw...   Aug 7 2018, 02:01 PM
cary   Well done .................. Don't forget to ...   Aug 7 2018, 11:56 PM
Jimz73   Well done .................. Don't forget to...   Aug 8 2018, 06:46 AM
cary   I was meaning all the rest of the lines. The rubbe...   Aug 8 2018, 07:17 AM
ClayPerrine   I would look into an electronic ignition to replac...   Aug 8 2018, 11:14 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:56 PM
