Brake Pedal Won't Release |
sdthomas |
Aug 11 2018, 03:23 PM
Member Group: Members Posts: 64 Joined: 14-June 11 From: Seattle Member No.: 13,193 Region Association: Pacific Northwest |
OK, ordered the 914Rubber MC. Thanks for the pressure bleeder offer, Tbrown4x4. I may take you up on it.
Tbrown4x4 |
Aug 12 2018, 08:36 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I didn't want to advertise only for Mike, but I bought his 19mm M/Cyl with the original fittings. I'm very happy with it. Best brakes I've had since I bought the car. (Also PMB caliper kits, hoses, and Porterfield pads.)
PM me if you need the bleeder. I can meet in Tukwila any evening or early morning. |
Spoke |
Aug 12 2018, 09:25 AM
The free play goes away once you push on the pedal. I checked it this morning and there was a little play in pedal. But it went away after using the brakes. When you say "free play", do you mean after the plunger in the MC is pushed or the free play in the pedal mechanism. The pedal mechanism is separate from the MC. Last year my brakes started sticking. I noticed the brake lights staying on. The problem was the pedal mechanism was binding. After applying some oil and penetrating fluid, the pedal mechanism loosened up and I've had no brake sticking issues since then. |
Porschef |
Aug 12 2018, 09:34 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
sdthomas |
Aug 18 2018, 06:19 PM
taylspin46 |
Aug 18 2018, 06:30 PM
Newbie Group: Members Posts: 24 Joined: 25-January 13 From: Apopka Member No.: 15,422 Region Association: South East States |
OK I'm ready to install my new MC. Removing the bolts from under the car seems easy enough but it's not clear to me how to detach the pedal rod from the cluster (or remove the rod from the old MC either). Is there a sequence to follow? The push rod sits in a cup in the m.c. When you remove thr m.c. The rod will come out. |
Lo-Fi Version | Time is now: 7th May 2024 - 10:46 PM |
