Engman Style Trunk Release, Nearly Done |
Nogoodwithusernames |
Aug 9 2018, 03:15 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Is anyone making a kit like the one Mr. Bland was making before he passed? My car already has a reflector and solenoid kit installed but of course it's iffy and requires two people when it does work (to depress the trunk lid). Or maybe have a list of components or some instructions for anything like it?
Figured after finishing up brakes this weekend *fingers crossed* I should make sure the rear trunk works since I've got a road trip planned with it in a few months. http://www.914world.com/bbs2/index.php?act...f=4&t=17486 |
jim912928 |
Oct 24 2018, 02:05 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I'm not home to snap pictures (can this weekend)...but I did install the engman kit. Mine routes thru the trunk, into the engine compartment, and if I remember right I brought it in near the floor on the drivers side. I then drilled a hole in the raised channel that separates the front floor pan from the rear floor pan (cable runs under the carpet behind and under the drivers seat). The pull looks nice and stock just under the seat. To pop the trunk I just reach between my legs and pull the knob.
Oct 24 2018, 04:00 PM
I'm not home to snap pictures (can this weekend)...but I did install the engman kit. Mine routes thru the trunk, into the engine compartment, and if I remember right I brought it in near the floor on the drivers side. I then drilled a hole in the raised channel that separates the front floor pan from the rear floor pan (cable runs under the carpet behind and under the drivers seat). The pull looks nice and stock just under the seat. To pop the trunk I just reach between my legs and pull the knob. If you could get some photos when you're home of routing through the engine compartment and up into the cockpit that would be fantastic! Much appreciated. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:42 PM |
