The alternator replacement thread, Fixed! |
VaccaRabite |
Aug 12 2018, 07:07 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Waiting on the side of the road for a flatbed to take me home.
Engine ran great. Charging system not so much. Driving along. Lights started going dim. Car started bucking. Only 5 miles to home but it wasn’t going to make it, and no shoulders to pull over safe on the little farm roads. So I pulled into a spot I knew of and shut it down and parked it and now I wait. McMark had said earlier he wasn’t sure about the charging system. But the alt light was not on and no issues before now. So. What’s the alternator I need to buy? Maybe a new VR as well? I guess I should test the battery and make sure it’s okay too. Zach |
VaccaRabite |
Aug 13 2018, 11:39 AM
Electrician for the house will be here in a few minutes, but I've searched all the grounds from the cockpit back. Battery to body is pristine. Trans to body has no corrosion. Every place that grounds in the engine bay was tip-top. I need to look in the cockpit yet, but I suspect things will be good there too. The car is kept indoors and I don't have that many miles on the body since the restoration ended back in 2009/2010. If the ground that are exposed to the elements are good, I have to think the cockpit grounds will be good too.
Zach |
Lo-Fi Version | Time is now: 17th May 2024 - 04:10 PM |
