The alternator replacement thread, Fixed! |
VaccaRabite |
Aug 12 2018, 07:07 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Waiting on the side of the road for a flatbed to take me home.
Engine ran great. Charging system not so much. Driving along. Lights started going dim. Car started bucking. Only 5 miles to home but it wasn’t going to make it, and no shoulders to pull over safe on the little farm roads. So I pulled into a spot I knew of and shut it down and parked it and now I wait. McMark had said earlier he wasn’t sure about the charging system. But the alt light was not on and no issues before now. So. What’s the alternator I need to buy? Maybe a new VR as well? I guess I should test the battery and make sure it’s okay too. Zach |
VaccaRabite |
Aug 20 2018, 04:07 PM
System still isn’t charging right.
I drove the car to the gym, and then around. Maybe 7 miles. Pulled into the house and got the mutimeter out. At idle I was showing 12.12 volts across the battery terminals. Revving the car to 3k and I was showing 12.06 across the terminals. I should be seeing more at rev. Grounds are good Alternator, voltage regulator, and voltage harness are all replaced. Gen light is acting like it should. I shorted D+ to DF and the engine loaded up and I saw 15 volts bear idle. So what’s next? Relay board? New VR still suspect? Zach |
Lo-Fi Version | Time is now: 16th May 2024 - 10:29 PM |
