The alternator replacement thread, Fixed! |
VaccaRabite |
Aug 12 2018, 07:07 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Waiting on the side of the road for a flatbed to take me home.
Engine ran great. Charging system not so much. Driving along. Lights started going dim. Car started bucking. Only 5 miles to home but it wasn’t going to make it, and no shoulders to pull over safe on the little farm roads. So I pulled into a spot I knew of and shut it down and parked it and now I wait. McMark had said earlier he wasn’t sure about the charging system. But the alt light was not on and no issues before now. So. What’s the alternator I need to buy? Maybe a new VR as well? I guess I should test the battery and make sure it’s okay too. Zach |
VaccaRabite |
Sep 8 2018, 05:17 PM
Goddamn happy dance.
14 volts at idle. 14 volts at 4K rpm. Using either of the single piece solid state VRs. Using the pig tailed solid state VR showed 13.5v. And the mechanical VR I got from Bruce was dancing from 13.5 to 14V. It was a grounding issue. I went back through the grounds, recleaned them, and added a 10 gauge wire from the alternator case to the chassis ground under the relay board. (I was doing that as you posted Spoke). Damn, that was a tough one. Still don’t know why the grounding issue was happening, as the meter said I was golden. But, clearly, the meter was wrong. Zach |
Spoke |
Sep 8 2018, 10:06 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Goddamn happy dance. 14 volts at idle. 14 volts at 4K rpm. Awesome! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 AM |
