Sheared CV Roll Pins and Bolts, Whats the permanent fix? |
FL000 |
Aug 12 2018, 07:42 PM
Member Group: Members Posts: 394 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
Recently got my car back on the road and have just over 300 miles on it. Mild SBC with 901 and Renegade CV shafts. Doing a hard pull in 2nd gear Friday and sounded like something exploded under the car - instantly lost all gears. Thought for sure I grenade the differential but it was actually where the outer CV joint bolts up to the drive flange. Destroyed both roll pins, and sheared 2 bolts. See pictures below.
What caused this and how to prevent it? Trying to take road trip with the wife in a week so want to get parts ordered asap. Too much torque? Maybe the bolts came loose? Other? If all my threads are good I plan to replace the roll pins and bolts and call it good. Maybe I'll add some thread sealant for insurance. Please advise. Thanks, Josh |
sbsix |
Aug 12 2018, 08:28 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 450 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
914 Rubber has the drilled bolts and SS wire.
mepstein |
Aug 13 2018, 05:55 AM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
wndsrfr |
Aug 13 2018, 06:25 AM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
FWIW, I safety wire my inside CV bolts along with known good schnoor washers. I guess it could be done with the outboard ones by pulling the hub, lots of work....
On the other hand for a "permanent" fix you could install a 1.7 (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 01:14 PM |
