Sheared CV Roll Pins and Bolts, Whats the permanent fix? |
FL000 |
Aug 12 2018, 07:42 PM
Member Group: Members Posts: 396 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
Recently got my car back on the road and have just over 300 miles on it. Mild SBC with 901 and Renegade CV shafts. Doing a hard pull in 2nd gear Friday and sounded like something exploded under the car - instantly lost all gears. Thought for sure I grenade the differential but it was actually where the outer CV joint bolts up to the drive flange. Destroyed both roll pins, and sheared 2 bolts. See pictures below.
What caused this and how to prevent it? Trying to take road trip with the wife in a week so want to get parts ordered asap. Too much torque? Maybe the bolts came loose? Other? If all my threads are good I plan to replace the roll pins and bolts and call it good. Maybe I'll add some thread sealant for insurance. Please advise. Thanks, Josh |
cali914 |
Aug 13 2018, 07:12 PM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
get the 100mm cvs from the early 911 6 bolts no dowels and get sway away to make the axles. Was it your passenger side you blew out? I blew mine out with a 3.5 liter v6 engine upgraded to 100mm set up and have not had a problem. You do have to get the inner cv transmission side off a 911 they are getting harder to find.
Lo-Fi Version | Time is now: 25th May 2024 - 02:00 PM |
