Yet another RennShift install |
campbellcj |
Jul 13 2003, 02:35 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I installed my RennShifter last night (& wrapped up this a.m. - didn't have a 7/32'nd hex). Very nice product and the installation was super simple, at least if you've ever played with the shifter assy before. Plus my car has no interior or console or passenger seat so the access is fantastic.
Anyways, the only small glitch is that there's a bit of interference with the clutch tube on the left side of the tunnel when going for 4th or 5th gear. I can get it in gear OK but it's definitely making a little contact. What's the preferred way to push/bend the tube for clearance? I don't want to kink or break it, obviously. Can I just kinda pry on it with a screwdriver or something? Or would it be better to try to clamp it out of the way with an adel clamp kind of thing? The shifter feels great (in the garage). (IMG:style_emoticons/default/smilie_flagge24.gif) Hoping to go for a drive this evening after a few more minor projects (IMG:style_emoticons/default/MDB2.gif) |
JWest |
Jul 14 2003, 07:51 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Sorry I missed this topic guys - had a big pool/yard game party at the house this weekend and I was a little busy/frazzled/worn out!
The clutch tubes are different in a lot of these cars - since so many have been broken and repaired and they always end up in different places. When I have needed to move the tube, I pulled out the heater lever and pried on the tube through that hole with a large screwdriver. The tube is quite malleable, so it doesn't take much force. The clamp is a good idea. Howard, I wish you had mentioned that yours was RHD, I could have put the shifter together backwards for you so the stick offset was on the other side. I'm glad you got it worked out. That is the beauty of the bolt-on steel stick, anyone can get steel welded for cheap and modify the stick for their preference. James- there are two different shifters for tail vs sideshift. I tailor the shifter to the exact application - prefered shift throw, tail or side shift, hand throttle slot or not, etc. |
Lo-Fi Version | Time is now: 16th May 2024 - 12:53 PM |
