What the Heck is that noise ?, Scrarey: good news was I was close to home |
jim_hoyland |
Aug 13 2018, 09:30 PM
Get that VIN ? Group: Members Posts: 9,269 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Driving home from thre powder coating shop today and all of a sudden this horrific metal-on-metal noise starts up from the rear passenger side.
Towed the car to PCH Garage for a checkout on the lift. Turned out the bolt holding the dust shield vibrated loose and the head began rubbing on the rotor. Whew.....that was sweet. Iām back on the road, glad to have caught in now instead of finding it happening on the trip to Monterey next month Attached image(s) |
Tbrown4x4 |
Aug 13 2018, 09:46 PM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Damn Jim. That's even beautiful on a flatbed! Glad it wasn't something major.
jim_hoyland |
Aug 14 2018, 04:36 AM
Thanks; the lesson is to use Loctite on those rotor dust cover bolts and tighten to spec...
914_teener |
Aug 14 2018, 06:53 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I had a pebble get in between the gravel shield and the rotor once......made the scariest grinding noise.
Hope to see you in the crowd in September Jim. |
ClayPerrine |
Aug 14 2018, 08:14 AM
Life's been good to me so far..... Group: Admin Posts: 15,426 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Toss the dust shields for better brake cooling.
jim_hoyland |
Aug 14 2018, 08:33 AM
Toss the dust shields for better brake cooling. Good point. I already removed the fronts... (IMG:style_emoticons/default/smile.gif) |
VaccaRabite |
Aug 14 2018, 08:49 AM
En Garde! Group: Admin Posts: 13,432 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I've had pebbles and once a rusty nail get between the dust cover and the rotor. What a racket!
I've also put my spare on and had my lug bolts go THUNK THUNK THUNK against the dust cover becasue they were for alloy wheels which are thicker then steel. That was my impetus for moving to wheel studs and lug nuts. No one wants to deal with THAT nonsense. Zach |
mepstein |
Aug 14 2018, 09:15 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've had pebbles and once a rusty nail get between the dust cover and the rotor. What a racket! I've also put my spare on and had my lug bolts go THUNK THUNK THUNK against the dust cover becasue they were for alloy wheels which are thicker then steel. That was my impetus for moving to wheel studs and lug nuts. No one wants to deal with THAT nonsense. Zach A lot of people have a steel spare and don't realize their alloy wheel bolts are too long and will hit the rotor - until they are stuck on the side of the road. |
jim_hoyland |
Aug 14 2018, 11:27 AM
I've had pebbles and once a rusty nail get between the dust cover and the rotor. What a racket! I've also put my spare on and had my lug bolts go THUNK THUNK THUNK against the dust cover becasue they were for alloy wheels which are thicker then steel. That was my impetus for moving to wheel studs and lug nuts. No one wants to deal with THAT nonsense. Zach A lot of people have a steel spare and don't realize their alloy wheel bolts are too long and will hit the rotor - until they are stuck on the side of the road. Will a 1/4ā wheel spacer solve that ? |
VaccaRabite |
Aug 14 2018, 01:44 PM
I've had pebbles and once a rusty nail get between the dust cover and the rotor. What a racket! I've also put my spare on and had my lug bolts go THUNK THUNK THUNK against the dust cover becasue they were for alloy wheels which are thicker then steel. That was my impetus for moving to wheel studs and lug nuts. No one wants to deal with THAT nonsense. Zach A lot of people have a steel spare and don't realize their alloy wheel bolts are too long and will hit the rotor - until they are stuck on the side of the road. Will a 1/4ā wheel spacer solve that ? Yes. But so would lug bolts for a steel wheel or simply going to wheel studs and lug nuts. IMO, getting a spacer for the spare just makes things more complicated. Studs also make the tire easier to change if/when you have to. Zach |
Lo-Fi Version | Time is now: 2nd May 2024 - 08:49 AM |
