More Info on Engine Blocks ? |
Beakster |
Aug 13 2018, 09:53 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
I have two 1.7 engine Blocks
the one in pieces Case n# is EA064290 The other in the car is EB005450 Would anyone have more info on engines by the Case numbers ?? |
jcd914 |
Aug 13 2018, 10:15 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
EA and E B engine cases are the same.
The EA engine was the 72/73 Rest Of World 1.7L engine. The EB engine was the 72/73 USA 1.7L engine with slightly low compression and HP. It was the pistons that were different to lower the compression. Jim |
porschetub |
Aug 14 2018, 12:01 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have two 1.7 engine Blocks the one in pieces Case n# is EA064290 The other in the car is EB005450 Would anyone have more info on engines by the Case numbers ?? Jeez easy to find anywhere ,use google..I do it before asking any question on what ever forum I'am on which is many and all rather different types of cars. The 1.7 "E'' cases are a great foundation for a build go 96mm with 2.0 litre heads you will be good,but you really need to change the cam if not going to FI. |
TheCabinetmaker |
Aug 14 2018, 06:46 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Why Google? That info is right under your finger. Top right corner of every page. It's called 914INFO.
Mark Henry |
Aug 14 2018, 06:59 AM
All Type four cases are basically the same with small differences.
-some very early 411 cases were mag and had no windage tray provisions, very rare. -bus cases have different drilling for dipstick, oil fill, fuel pump (carb), lifter pressure relief (late cases not drilled),etc. -similar differences as bus for 411/412 cases. Biggest issue with using bus or 411/412 cases in a 914 is the dipstick tube. For 914 the only difference in the 1.7,1.8, 2.0 cases is where the serial number is. I don't know for sure but the euro carbed 914 may have the fuel pump area machined for the mechanical pump. The 1.7 "E'' cases are a great foundation for a build go 1.7/1.8 are the often best cases for any build, the shorter stroke crank is stronger and has less flex than the longer 2.0 crank, therefore causing less wear to the case. |
bdstone914 |
Aug 14 2018, 08:51 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
All Type four cases are basically the same with small differences. -some very early 411 cases were mag and had no windage tray provisions, very rare. -bus cases have different drilling for dipstick, oil fill, fuel pump (carb), lifter pressure relief (late cases not drilled),etc. For 914 the only difference in the 1.7,1.8, 2.0 cases is where the serial number is. I don't know for sure but the euro carbed 914 may have the fuel pump area machined for the mechanical pump. The 1.7 "E'' cases are a great foundation for a build go 1.7/1.8 are the often best cases for any build, the shorter stroke crank is stronger and has less flex than the longer 2.0 crank, therefore causing less wear to the case. (IMG:style_emoticons/default/agree.gif) I saw a VW 412, 1.8L case that had the mechanical fuel pump that mounts to the rear of the case. |
dr914@autoatlanta.com |
Aug 14 2018, 09:09 AM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Mark Henry |
Aug 14 2018, 10:59 AM
I edited my post above for 411/412 and "Biggest issue with using bus or 411/412 cases in a 914 is the dipstick tube."
Mark Henry |
Aug 14 2018, 11:02 AM
All Type four cases are basically the same with small differences. -some very early 411 cases were mag and had no windage tray provisions, very rare. -bus cases have different drilling for dipstick, oil fill, fuel pump (carb), lifter pressure relief (late cases not drilled),etc. For 914 the only difference in the 1.7,1.8, 2.0 cases is where the serial number is. I don't know for sure but the euro carbed 914 may have the fuel pump area machined for the mechanical pump. The 1.7 "E'' cases are a great foundation for a build go 1.7/1.8 are the often best cases for any build, the shorter stroke crank is stronger and has less flex than the longer 2.0 crank, therefore causing less wear to the case. (IMG:style_emoticons/default/agree.gif) I saw a VW 412, 1.8L case that had the mechanical fuel pump that mounts to the rear of the case. Sure it wasn't a bus case? 411/412 used an early D-jet FI system in north america. Bus had carbs till 75 and the mechanical fuel pump. |
Dave_Darling |
Aug 14 2018, 05:35 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:00 AM |
