Not a 914 but need brain trust help...., 944 turbo oli won't show on dip stick..... |
second wind |
Aug 17 2018, 07:39 PM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
I know I am off topic by one digit but maybe someone can help....I just changed the oil in my '89 944 turbo and have put at least 7.5 quarts of oil into it....but it doesn't hit the dip stick yet. Never had this problem before. No leaks or anything....good oil pressure....and even if the new oil is so clean you couldn't see it it would still be wet and shiny....which it isn't. I am afraid to put more oil in.....most sources say 6.5 quarts should do it.....anybody have any ideas on this? Very weird....
Thank you, gg |
iankarr |
Aug 17 2018, 08:40 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Strange.Is it possible the PO added a deep oil pan / sump?
michael7810 |
Aug 17 2018, 08:54 PM
Senior Member Group: Members Posts: 1,080 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
The dipstick tube could be coming out of the block. There's a tab on the tube with a bolt that holds is in place...see if that is loose or missing. Seems to me I add 7 quarts in my 944 turbo at oil change and that puts the oil slightly above the full line on the dipstick. Is this the first time you've changed the oil? I have not heard of people using a deep sump on 951s and while I'm no expert I do read the forums often (Oh wait...maybe that does make me an expert).
worn |
Aug 17 2018, 09:18 PM
can't remember Group: Members Posts: 3,150 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I know I am off topic by one digit but maybe someone can help....I just changed the oil in my '89 944 turbo and have put at least 7.5 quarts of oil into it....but it doesn't hit the dip stick yet. Never had this problem before. No leaks or anything....good oil pressure....and even if the new oil is so clean you couldn't see it it would still be wet and shiny....which it isn't. I am afraid to put more oil in.....most sources say 6.5 quarts should do it.....anybody have any ideas on this? Very weird.... Thank you, gg After checking for dipstick damage I would add oil maybe a half quart at a time until you see it on the stick. Until you see something you don’t know. Regardless of what you think the number should be. |
914-300Hemi |
Aug 17 2018, 09:36 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
It also depends on if you have front oil cooler.
I would recommend adding a 1/2 quart at a time and check. |
bdstone914 |
Aug 18 2018, 06:45 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Over filling is not good. Causes the crank to splash through the oil whipping bubbles not the oil. Make sure the dip stick tube is not pulling out.
second wind |
Aug 18 2018, 08:49 AM
This is the second time I have changed the oil and no issues on first oil change. The dip stick tube idea has been mentioned by several people....I will check. How would I remove oil if I have too? Suck it out from oil fill or dip stick tube? Thank you very much you guys!!
gg |
second wind |
Aug 18 2018, 09:14 AM
I just checked the dip stick tube.....it is bolted in and tight. I am not crazy but the oil must be somewhere....I will try the half a quart at a time method and see what happens......
gg |
second wind |
Aug 18 2018, 09:29 PM
Ok.....I believe I am eight quarts in but at least it is showing on the stick.....I found one post saying turbos take 7.4 quarts of oil.....maybe I drained the snot out of this car and just have to keep adding oil? I measured the oil I took out and it was 7 quarts.....plenty of oil pressure .....thank you for your help!
gg |
michael7810 |
Aug 19 2018, 05:55 AM
I checked my records and I added 6.25 Qts on my last oil & filter change. The owners manual says “approx” 6.87 qts with filter. Only a German would give an approximate oil capacity with 2 decimal places. Anyway 8 qts should be way too much oil for a stock engine. The dipstick in my car measures 20-3/4” from the edge of the plastic to the tip or 19-1/2” from the edge of the plastic to the bottom (low oil) notch.
Rob-O |
Aug 19 2018, 06:53 AM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Not sure what brand oil you’re putting in, but is it possible that you’re getting shorted in the bottle? Maybe instead of a true quart you’re getting 7/8 of a quart?
Also, and this may have been mentioned earlier, do you have an external/aftermarket oil cooler? Maybe a different oil filter (i.e. more capacity) than what is recommended for the car? |
Beebo Kanelle |
Aug 19 2018, 09:01 AM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Drain it.
Measure the volume. See if there's any loss. Check dipstick for any interference which would prevent complete seating |
rgalla9146 |
Aug 19 2018, 09:28 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I'm sure you would have mentioned it but......is it a new engine ?...did you replace the oil pan ? either one would require some additional oil.
second wind |
Aug 19 2018, 11:43 AM
Not sure what brand oil you’re putting in, but is it possible that you’re getting shorted in the bottle? Maybe instead of a true quart you’re getting 7/8 of a quart? Also, and this may have been mentioned earlier, do you have an external/aftermarket oil cooler? Maybe a different oil filter (i.e. more capacity) than what is recommended for the car? I am using Valvoline 20-50 VR1. This is a puzzlement and thank you for your comments. I think there is a slight bow in my dip stick so I will try to straighten and see if there is improvement. gg |
second wind |
Aug 19 2018, 09:42 PM
Ok....all done....final post on this...for now of course....I got the oil up to the high mark on the dip stick but it took ten quarts....maybe a little less ....I know you think I am nuts or drunk or high or stupid but I am not.....I measured the old oil and it was seven quarts and I was good on the stick.....the only explanation is that Valvoline sells short quarts.....what else could it be? I am leaving in turbo tomorrow for a 1,000 round trip to June Lake, Calif. Just up the street from WCR 2017 which I attended.....944 is a luxury car compared to 914 (no offense anyone) and twice as fast easy so I am taking it.....I will measure a quart of Valvoline in the same container I have and see how it measures up pun intended...or whatever....this has been stressing me out as too much oil will ruin your whole day...and then some. Thank you again all for your care and help.
gg |
michael7810 |
Aug 20 2018, 10:58 AM
Ok....all done....final post on this...for now of course....I got the oil up to the high mark on the dip stick but it took ten quarts....maybe a little less ....I know you think I am nuts or drunk or high or stupid but I am not.....I measured the old oil and it was seven quarts and I was good on the stick.....the only explanation is that Valvoline sells short quarts.....what else could it be? I am leaving in turbo tomorrow for a 1,000 round trip to June Lake, Calif. Just up the street from WCR 2017 which I attended.....944 is a luxury car compared to 914 (no offense anyone) and twice as fast easy so I am taking it.....I will measure a quart of Valvoline in the same container I have and see how it measures up pun intended...or whatever....this has been stressing me out as too much oil will ruin your whole day...and then some. Thank you again all for your care and help. gg (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
whitetwinturbo |
Aug 20 2018, 09:42 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
.....watch out for checking oil when car is not level (IMG:style_emoticons/default/poke.gif)
Lo-Fi Version | Time is now: 4th May 2024 - 05:16 AM |
