More electric wire help |
Wew |
Aug 18 2018, 09:05 AM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
I took 3 pictures from the center tunnel and dropping from the dash. The 4 little wires I think should have gone into a plastic housing which would plug into one of the gauges in the appearance group housing. There is also a little brown wire that is part of the harness and is short and a bigger red one that is laid on top of the harness (aftermarket)? Your input is much appreciated as I am getting close to getting this project on the road. Thanks much, Gary |
Wew |
Aug 18 2018, 09:07 AM
Wew |
Aug 18 2018, 09:09 AM
Mike Bellis |
Aug 18 2018, 09:33 AM
Aftermarket. Oil pressure maybe. You will have to track it down in the rear.
JeffBowlsby |
Aug 18 2018, 12:05 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Center console gauge wiring - think about defrost light on the center console.
The long branch of the 4 wires from the dash may be for the pass side door switch if you have an early model year car. |
Lo-Fi Version | Time is now: 24th April 2024 - 08:27 PM |
