| windforfun |
Aug 18 2018, 09:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,090 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
| TheCabinetmaker |
Aug 18 2018, 09:52 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,360 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Adjust idle after it's warmed up
| rhodyguy |
Aug 18 2018, 10:15 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What is the RPM after the drop?
| bbrock |
Aug 18 2018, 10:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
And to answer the question about "why," IIRC it is because when the engine is cold, the auxiliary air valve is open to let more air in and idle the engine faster. After it warms up, the valve closes and the idle settles to what you want it set to. It has been decades since I've messed with D-jetronic so I'm sure someone can verify or correct this.
| dr914@autoatlanta.com |
Aug 18 2018, 10:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,225 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 13th January 2026 - 10:18 PM |
