| ClayPerrine |
Aug 24 2018, 01:07 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The only time you should run 0 lash is when you run steel pushrods. The expansion rate on steel pushrods is the same as the cylinders, so they don't tighten up as they get hot.
When running the stock aluminum pushrods, you need to run factory valve lash settings. It accounts for the fact that aluminum expands more than steel when heated, so when your engine running aluminum pushrods is hot, it is at 0 lash. That's why you have to set the valve when the engine is dead cold. |
Lo-Fi Version | Time is now: 6th September 2026 - 10:25 PM |
