> Anyone have a source for stepped bearing dowel pins
Driver174
post Aug 22 2018, 11:14 AM
I’m looking for stepped up pins so I can increase diameter of mating hole in case but use unaltered bearing.
What is the fix for a worn dowel / case? I’m going to try a new dowel but I’m expecting it to be less than a tight fit.
Mark Henry
post Aug 22 2018, 11:22 AM
that's what I do!
On the type one case I machine drill it oversize for a press fit aluminum plug, then drill it to dowel size and finish it off by line bore the case for OS bearings.
- Lo-Fi Version Time is now: 17th April 2026 - 06:57 AM
