defianty |
Senior Member ![]() ![]() ![]() Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None ![]() ![]() |
I see that JP group are reproducing 914 gas tanks now. Seeing that mine is quite rusty inside and needs new paint these look very tempting. They're very well priced too.
http://www.jpgroupclassic.com/productview.aspx?ID=1615600600 Has anyone seen one yet? |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,889 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Since my car is a 75, the canister is in the engine compartment. Looks perfect for that application.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,028 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Since my car is a 75, the canister is in the engine compartment. Looks perfect for that application. No it is not. The bracket it does have is for the early steel expansion tank. Technically only correct for a 1974 late. They will work on prior years but lack the charcoal canister brackets as noted. Listed on the Pelican site at $204. https://www.pelicanparts.com/catalog/SuperC...L_pg3.htm#item9 Out of stock till mid september. Bruce |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Since my car is a 75, the canister is in the engine compartment. Looks perfect for that application. No it is not. The bracket it does have is for the early steel expansion tank. Technically only correct for a 1974 late. They will work on prior years but lack the charcoal canister brackets as noted. Listed on the Pelican site at $204. https://www.pelicanparts.com/catalog/SuperC...L_pg3.htm#item9 Out of stock till mid september. Bruce That's a better price. Wholesale to shops is around $150 |
Lo-Fi Version | Time is now: 5th July 2025 - 02:49 PM |
